Feature Request? Dropwatch
Hello guys,
Does anyone know if Mikrotik ever considered adding https://github.com/nhorman/dropwatch to their operating system?
I had a hard time figuring out RP Filter was dropping packets and Dropwatch would definitely help understanding rp filter / filter drops.
Thank you
I would rather like to see the “rpfilter” matcher in the firewall so that packets not matching rpfilter can be dropped or marked as usual in firewall rules, including the usual way of counting and logging them.
Linux iptables has this “rpfilter” matcher as documented in the man page:
   rpfilter
       Performs a reverse path filter test on a packet.  If  a  reply  to  the
       packet would be sent via the same interface that the packet arrived on,
       the packet will match.  Note  that,  unlike  the  in-kernel  rp_filter,
       packets  protected  by  IPSec  are not treated specially.  Combine this
       match with the policy match if you want this.  Also,  packets  arriving
       via  the  loopback interface are always permitted.  This match can only
       be used in the PREROUTING chain of the raw or mangle table.
       --loose
              Used to specify that the reverse path filter test  should  match
              even if the selected output device is not the expected one.
       --validmark
              Also  use  the packets' nfmark value when performing the reverse
              path route lookup.
       --accept-local
              This will permit packets arriving from the network with a source
              address that is also assigned to the local machine.
       --invert
              This  will  invert  the sense of the match.  Instead of matching
              packets that passed the reverse path filter  test,  match  those
              that have failed it.
but for some reason unclear to me it is not available in the RouterOS firewall rules…
