feature request: ECMP Settings
please add both addresses and ports choice (option) for ECMP under IP->Settings
thanks!
thanks!
So… what do you think ECMP is?
Currently?
Only address combination. Different ports get same route
EDIT: WE HAD TO USE PCC FOR LOAD BALANCING, BUT WOULD PREFER ECMP INSTEAD.
Use both addresses and both ports in PCC. No broken connections and very good distribution.
At the time of writing this post ECMP is layer2/3 only. In the future we might enable also layer4.
must have. ECMP is the future, imo.
