2jarek
August 3, 2017, 7:37pm
1
Nstreme after 4 years still better performance than NV2.
Please consider upgrade old Nstreme like this:
Aggregation - Framer limit beyond 4000 bytes maybe 8000 or 64000b (good for 40&80Mhz channels) ?
Different Framer limit for download & upload. Maybe exact size 64000b DL & 500 for UL (At the expense of upload greater resistance to noise)
Fast reconnect after DC no scan all scan list channels just reconnect again in milliseconds.
4)Update Nstreme for AC http://forum.mikrotik.com/t/nstreme-ac-no-more-than-170mb-throughput-6-19-6-20rc/81067/1
Cha0s
August 4, 2017, 12:23pm
2
+1
I still use Nstreme for PtP links. I’d love to see some improvements. NV2 is nice for PtMP but not for PtP IMHO.
2jarek
August 9, 2017, 8:31am
3
diode
August 9, 2017, 10:51am
4
Me too …
I still run the whole ISP on nstreme, its faster here when you have a low count of clients each sektor (4-5 …).
BR from Vienna !
Nstreme may have better performance than NV2 for PTP but when I try to use it links keep disconnecting, so Nstreme is not as robust to co-location interference as NV2 is,
so add to requested features
4) Co-Location Interference suppression
Try disabling CSMA if you haven’t:
/interface wireless nstreme
set wlan1 disable-csma=yes enable-nstreme=yes
The fine manual suggests that NV2 disables it automatically.
2jarek
August 9, 2017, 7:53pm
7
pants6000:
All time disable CSMA …
Nv2 use dynamic aggregation & make smaller frames if no need.
