expert
1
Please implement append=yes option to the export command.
Use case: I’d like to perform router-to-router (partial) config transfer described in the following use case.
/ip dhcp server lease export file=config.rsc append=yes
/ip dns static export file=config.rsc append=yes
expert
2
So, nobody here found this feature useful?
We are all wearing false teeth because we lost those the real ones chewing on this. Do it manually on your own computer.
Maybe it will be in ROS7 like many other unicorns.
