Feature request - Fetch tool
Hi guys. is it possible to http fetch to local device file like dev/null.
When running the tool on a scheduler, i do not want to break the onboard flash after numerous writes.
this not help you?
/tool fetch
M.
i would also like to store the output of the fetch tool either in a variable or /dev/null it as well. trying to get my flash writes down as well.
