[Feature Request] Force WebFig to HTTPS
It would be nice if there was a way to force WebFig to go over to HTTPS..
Do you mean add an option to automatically redirect http → https?
Otherwise you could just disable the www service. :slight_smile:
Yes.
any updates about this?
Force use https instead http?
I can only make to use booth ssl and not ssl, or only one of them. But how to make force redirect to https?
try diable http service and put https service on 80 port maybe ? :wink:
