Feature request: host list
Some devices/servers have static IP addresses, and they are referenced in several places: DHCP Server, Firewall, NTP… You have to write down the same address everywhere. But what if those addresses ever change? You’d have to check all your router’s configuration!
It would be great to have a place to register this hosts: just a name and an IP address. Then, you could reference it in router’s configuration. For instance:
  • firewall nat rule’s “To Addresses” field
  • firewall rules’ “Src. Address”/“Dst Address” fields.
  • DHCP Server’s “Address” field.
  • SNTP Client’s “Primary/Secondary NTP Server”.
  • member of an Address List
Some kind of implied security is needed to avoid deleting a host used in other place.
If you change IP address of a host, configuration is automatically adapted to the new address, as Address Lists changes do.
Wouldn’t it be great?
P.S.: Maybe this can be achieved with variables and scripting, but I’m not so expert user, just an amateur Winbox user :wink:
Whats wrong with “Address list” definable in IP/Firewall?
usable address-list to fill this filed? NO
usable address-list to fill this filed? YES
(I think gateway and other parameters on networks?) usable address-list to fill this filed? NO
??? what mean ???
Are these features necessary? for me NO
The “check all your router’s configuration” is not hard.. make an export of the configuration (text file) and search for the address in this file.
