Wondering if I might be able to get https (and sftp) enabled for the fetch command?
Specifically for sites like this - https://customer-webtools-api.internode.on.net/unmetered_ip_address_list.txt
where only https is supported (the companies server has other username/password/usage responses they don’t want passing in plaintext)
Is this a possibility and is there anyone else out there currently using the fetch command who would benefit from this?
Regards,
Omega-00
