[ This could apply to both GUI and CLI although I use CLI way more than GUI ]
Show unused options in another colour so it’s obvious which ones have NO effect in current state.
e.g. channel-width is decided by AP, not station so the value here is unused
[admin@mikrotik] /interface wireless> pr advanced
0 R name=“wlan” mtu=1500 mac-address=4C:5E:0C:D0:FF:FF arp=enabled
disable-running-check=no interface-type=Atheros AR9300
radio-name=“4c5e0cd0ffff” mode=station ssid=“wifi” area=“”
frequency-mode=regulatory-domain country=united kingdom antenna-gain=16
frequency=5625 band=5ghz-onlyn channel-width=20/40mhz-eC scan-list=5625
wireless-protocol=802.11 rate-set=configured
supported-rates-a/g=“” basic-rates-a/g=“” max-station-count=2007
distance=dynamic tx-power-mode=default noise-floor-threshold=default
nv2-noise-floor-offset=default dfs-mode=none vlan-mode=no-tag vlan-id=1
wds-mode=disabled wds-default-bridge=none wds-default-cost=100
wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled
bridge-mode=enabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0
proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no
security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms
preamble-mode=both compression=no allow-sharedkey=no
station-bridge-clone-mac=00:00:00:00:00:00 ampdu-priorities=0
guard-interval=any ht-supported-mcs=mcs-8,mcs-9,mcs-10,mcs-11,mcs-12
ht-basic-mcs=“” tx-chains=0,1 rx-chains=0,1 amsdu-limit=8192
amsdu-threshold=8192 tdma-period-size=2 nv2-queue-count=2
nv2-qos=default nv2-cell-radius=30 nv2-security=disabled
nv2-preshared-key=“” hw-retries=7 frame-lifetime=0
adaptive-noise-immunity=none hw-fragmentation-threshold=disabled
hw-protection-mode=rts-cts hw-protection-threshold=0 frequency-offset=0
rate-selection=advanced multicast-helper=default
multicast-buffering=enabled keepalive-frames=enabled
At the very least it would help if there were some extra columns on http://wiki.mikrotik.com/wiki/Manual:Interface/Wireless#General_interface_properties like “AP” or “NV2” which have ticks or ✘crosses in to show if they’re used or not.
So for channel-width, there’d be a for AP and a
for NV2 (and nstreme and 802.11).
For tdma-period-size there’d be a for AP,
for NV2, ✘ for 802.11 and ✘ for nstreme (I think).
Certainly adding the columns to the WIKI wouldn’t take too much space and should be relatively quick.
