feature request : ipsec with mode_cfg
Hi there,
I’ve been working since a while with ipsec-tools and l2tpns in linux as a server vpn. The most of the client are windows, native connections (ipsec/l2tp) or using a client ShrewSoft (great soft!).
Ipsec-tools let you simplify the connection using the mode_cfg (gather network information through ISAKMP mode configuration). The client Shresoft was developed to understand this and create the necessary interface and routes.
I was wondering if there is any plan to implement this in ROS, I mean ROS can take the advantage of this mode_cfg as a client to create the virtual interface.
It would be really nice. Thanks.
/rodrigo
Where you ever able to get the Shrewsoft VPN client to connect to ROS?
I’ve not very knowledgeable about IPsec setups so I need to know if it is possible.
If it does work, are there step-by-step directions somewhere?
