Feature Request : L2TP Connection / Packet Mark
Please add functionality to enter Connection or Packet Mark in L2TP Client Profiles, because currently there is no way to Mangle different L2TP Client connections (‘Dial Out Routing’).
Thanks,
regards
Marcus
Any comments on that ?
Have you tried assigning a different address pool to each client profile, and doing the mangling based on the IP address?
Thanks for you answer.
At that moment my L2TP client going to ‘Dial Out’ i have no IP Pool Information.
My problem is i need to mangle and route 4 L2TP Client, only difference the user name is, to 4 different dynamic ISP WAN ports. I use that to bind 4 DSL Connections. Currently i need 4 Mikrotik Router to do that, each per L2TP Tunnel :open_mouth:
So these are connections that dial out from your router, instead of inbound connections?
