feature request; less case sensitivity
My sometimes text editor, google docs makes new lines start with a caps letter. My preferred nano doesn’t do this.
But if I type up some template, it would be nice if RouterOS were not as fussy about capitalization when it should not matter.
e.g. Add does not work but add does.
When you asked “Google” to change google docs so that it doesn’t automatically capitalize new line, what did they say to you?
This tendency to pretend that because of others one must modify the behavior of one’s programs denotes many things.
Above all, where is it written that Google Docs is recommended as an editor for RouterOS scripts?
Obligatory xkcd, workflow :wink: :
https://xkcd.com/1172/
:laughing:
I know… Woe is to me because not vi or emacs…
Then imagine potential ROS CLI issues like this https://superuser.com/questions/1693115/case-sensitive-commands-in-bash-shell if commands would be case insensitive (even on interpreter commands, not fs) :slight_smile:
No. Just… no. They are different characters, should be treated in a different way.
