Would it be possible to add a filter based on a mangle rule to torch?
This might be a good feature to have.
Dan
Dan
That would be excellent. Also. Torch filtered by queue would be awesome job.
Till then, you may use IP firewal connection list. It shows packet marks.
Thank you for pointing that out. The only downside is that it only shows connection marks.
Dan
If you played a while with MT you will find out that it has quite a lot such
points, when it offers powerful stuff, but not simple options or options to provide higher usability.
