feature request: MT WinBox icon upgrade
The current icon for winbox is a ridiculously low resolution image.
Please upgrade this to a vector based image that could actually scale well with different resolutions.
This is a feature that would make it look the part (which is the high end router software it is :slight_smile: )
icons can’t be vector. this is a windows limitation.
actually winbox contains all needed resolution icons, but there is some bug that it doesn’t show correctly in the task bar. it is correct in the file browser and desktop
