Feature request : Ping check Gateway
Dear Mikrotik support, it would be great if it was possible to choose the gateway to ping in /IP route.
At the moment, only the gateway is possible. I’d like to be able to choose another IP as 8.8.4.4 for example.
Thank you in advance,
You can do this recursively.
http://forum.mikrotik.com/t/advanced-routing-failover-without-scripting/136599/1
Thank you for your answer, but it’d be easier to implement it directly :slight_smile:
