Feature Request: Processor, USB 3.0, M.2, and MSata Driver Support
RouterOS is a wonderful tool, but without the ability to use it with devices that only have these options (USB 3.0, M.2, and MSata) we are running into issues being able to use the software on newer devices. Any device with a x86 6th+ gen Intel processor, Ryzen AMD processor, or only has 3.0 USB ports are render useless when it comes to being able to use RouterOS.
It would be nice to have the ability to use these pieces of hardware with RouterOS.
Feature Request:
Driver Support for the following:
x86 6th+ Gen Intel Processors
x86 Ryzen AMD Processors
USB 3.0 +
M.2 SSD
MSata SSD
Whilst not bare metal. You can use these features easily if you run a CHR instance.
