Feature Request - Quick Set Options
Great idea the Quick Set… congratulations.
But, is better if add to the Wlan settings on Quick set:
band
ssid
and, set the radio-name same as Router identify.
band
ssid
SSID you can already set (below the scan window there is a SSID box)
Band - currently supported devices only have one band supported (RB711, SXT, Groove) but thanks, we will add that for other models.
