Feature-Request: QuickSet - enable RoMON
it would be nice to have a checkbox in Quick Set for enabling RoMON in WebFig and WinBox, maybe near the password field.
Cheers,
Ralf.
There is some balance to be found, between what people really need and what can be found confusing by new users. We can’t fit everything there. Maybe we need some kind of brainstorming topic about QuickSet modes? Suggestions about features to be added/renamed/removed from each QuickSet mode.
Let me storm your brains: Make the quickset to be separate removable package.
+1
Either separate package or winbox option to load into quickset only.
Simplified port forwarding settings might be a nice feature for QuickSet. You can say it’s already simple enough, but still many people have problems with it. If they could just enter port and target address and QuickSet would do the rest, including hairpin NAT, I think they would like it.
Maybe there can be a branch of ros for dummies with hundreds pages and windows full of single tick quickset powered features along with the standard ros with no quickset at all…
+1 even can be on the bundle package , enable as default but make possible to disable if we want
also make basic mode and advanced mode and wireless and ethernet settings separated by TABs
on basic mode
can be just like it is now, maybe some tweaks, moving some settings to adv mode
on advanced mode
a more customized things
  • choose which interface will be used as wan/lan interface
  • services port
+1
At least make possible to disable it. :smiley:
