I wish to have a wireless bridge where I can bridge my vlan trunks without untagging-bridging-tagging it on wireless- …
Simply make a bridge, put both interfaces in trunk mode
I do not understand your problem.
You can create bridge put two wireless interfaces (note mode=station does not support it due to the limitation of 802.11), then VLAN data will pass correctly trough it.
‘interface bridge’ firewall menu allows to filter traffic trought bridge.
Hmm, if it is as you say it will be perfect.
Reading some articels in the forum. They said that you will have to create a virtual accesspoint and put this into a bridge within a vlan-ethernet.
Ýou 're shure that the tagged packets travel through the single bridge?
Should reading before writing … ![]()
You said “two wireless interfaces”
I mean an Ethernet-Interface (trunk) bridged over the wireless link
Yes, VLAN frames are passed transparently trough ‘bridge ports’, it does not matter wireless or Ethernet interface is added (only mode=station does not support bridging).
So would the following also work? :
Idea is to connect 2 remote sites via an intemediate hop so that changes can be made to vlan database on switches without having to change anything on Mikrotik side. We are currently bridging the ethernets to EoIP tunnels between the CPE’s but there seems to be problems when it passes high traffic levels so would prefer a less CPU intensive solution.
Vlan transport over wireless bridge (WDS) is working perfectly. No limits.
Plus, you can add management vlan to bridge interface.
You can read more about how to build VLAN over a wireless network from our presentation in MuM in Krakow, http://mum.mikrotik.com/presentations/2007_1/PL07_Roamingwire.pdf
Paul
