For all us guys that like to stick with defaults
, let’s have new command, something like this:
[admin@MikroTik] > /system reset set restore_interface=wlan1 keep_ssid=lets_start_from_scratch
Not So Dangerous Anymore! Reset anyway? [y/N]:
it’s easy to do that already. you first must apply the defaults by giving an RSC file to Netinstall when you install it. then, when doing a system-reset, the RSC file commands will be applied, unless you say “no-defaults” in the command parameters
