It would really help, if on the “main login page” of the router, that a “location” line could be put in. Also at the top of each page next to the “Webfig”. This would help identifying the exact router that you have logged into.
When we are doing some maintenance, we sometimes go back and forth to several routers. It would help if you knew easily which one you had accessed.
NO, we just log into the router via them. It would just be nice when you do so, to know where that router is located, instead of what firmware version it currently has ? An “Identity” line on the webfig login page would be helpful !
