Hi guys,
it seems like the default configuration for each different type of installation is different
- RouterOS on RB450G - default creates a bridge - uses bridge+eth2-eth5 for private net
- RouterOS on RB750 - does not create a bridge - uses eth2-eth5 for private net
- RouterOS on x86 - uses ETH1 for private net as default.
Is there not a way to make a std configuration that always uses ETH1 for public and ETH2-ETHxxx as private? and maybe always create a bridge?
So ONE std. configuration for any version of RouterOS? - or have a range of Std. Configurations you can select between when connecting with WinBox the first time?
/kaz
