in short – is there any chance to set NTP servers using DNS names? Like this:
/system ntp client set primary-ntp=ntp1.xxx.cz secondary-ntp=ntp2.xxx.cz
I know that it can be done from Winbox, but the joke is that it only translates the DNS names to fixed IP addresses in-place, and saves the IP addresses.
It would be nice if DNS names could be saved, so that the routers for example automatically use new NTP servers on change, or auto-rotate pooled NTP servers.
Thanks for the answer (or at least for a reason why is this not possible :] )
-exa
