Feature Request: Simplified RouterOS and config update.
Hello Mikrotik team!
We need more simplified RouterOS and config update.
It may be something like press to the 4 buttons and take no more than 1 minute, as example.
For this we need:
  1. Android phone as source of RouterOS packages and configs.
  2. RJ45 to microUSB adapter.
  3. PoE adapter to power device via Ethernet port.
  4. Power source to power device.
This can be very usefully in projects like a:
Internet in the bus.
Internet in the trolleybus.
And may be in another projects where device can be restored by people without knowledge of ROS and config upgrade process.
[attachment=0]RouterOS-Feature-Request-Simplified-RouterOS-and-config-update.png[/attachment]
Thank you!
Related information
Manual:Netinstall
do you sure its good idea to do anything by people “without knowledge” ? :=|
“mobile outdoor installation kits” supplied by some companies, but i never saw that really popular(and probably explain why they are no more)
When you have a business case for that, you can develop an app that does it.
The MikroTik routers already have the required API for it.
When asking for buttons for firmware update, have you considered also the software update? Using api is the right way for you. I am pretty sure that mikrotik will not do it.
