Feature Request: Static Link Local Address
Some providers with IPv6 require you to override the default link-local address of an interface with a static one like fe80::1 or fe80::2. This is possible with most routers, but currently, there is no ability on MikroTik routers to manually specify a link local address on an interface to override the auto-generated link local. Might this be possible in RouterOS v7?
Thanks!
