Hi Folks,
I’m trusting that someone from the Mikrotik development team will see this. I’ve been running SwOS on a CRS354-48P-4S+2Q+ for a small church, without any major issues. Recently I decided to try out LibreNMS and I’ve discovered that there is a character limitation in the SNMP Location field, which prevents the entry of data in the format that LibreNMS recognizes in order to successfully parse out GPS coordinates from that field.
LibreNMS expects to see something like this for syslocation: “Rack, Room, Building, City, Country [GPSX,Y]”. It appears the field is currently limited to 32 characters, but I need about 52 characters to support my current use case. As such, I’m requesting that this field be increased to support at least 150 or 255 characters.
Thanks for your consideration.
