Hi Mikrotik team!
I want to offer some new keys.
I think that these parameters are necessary for a more flexible use of the Torch function.
- NOT function for Src/Dst/Ipv4/6 ..
- Group by ip Src/Dst
- Group by port
- Torch with many IPs like this
— 91.24.23.22,102.64.10.1 (separeted with comma)
— 91.24.23.22-102.64.10.1,64.25.10.11 (range + ip/ips)
— select “Address List” from firewall Address lists - Port range select (80-8080) or (80,443,555-1000)
- Connection view limit 200/500/1000/5000/none (helps when a lot of connection on winbox screen)
- Export to clipboard - copy torch session to clipboard in text format, or other
- DNS lookup in Src/Dst input (if there is a lot of IP for a DNS name, then a torch with this range of IP addresses)
- DNS lookup in view(result) screen - activate by select (not in the picture now:
Thanks!
Be the best!
Photoshop version ![]()
