Feature Request: USB CH340 usb-to-serial support.
I want to use CH340 usb-to-serial adapter. but Mikrotik not support yet.
Please make it support for this chip.
i saw ch341 kernel module in the newly released routeros7.0 beta1.
tomorrow i will hook on a ch34x based USB to serial to the upgraded router and report back my findings.
It may be possibly different for other architectures, but my usb-to-serial cable that reports as CH340 in Windows, works fine with CHR 6.45 (it’s a little unusual to test it there, but right now I don’t have physical RB with usb port here). I was able to connect from another PC over serial cable, so it really works.
[admin@MikroTik] > system resource usb print detail
 3 device="2-2" name="USB2.0-Ser!" vendor-id="0x1a86" device-id="0x7523" speed="12" usb-version=" 1.10"
[admin@MikroTik] > port print detail
Flags: I - inactive
 0   name="usb1" used-by="Serial Console" device="" channels=1 baud-rate=9600 data-bits=8 parity=none stop-bits=1 flow-control=none
just tried with this chinese arduino nano knockoff which has a WCH340G usb serial adapter, and it works fine. i agree, the device naming is somewhat medeival:
[admin@hgw] > /system/resource/usb/print
Columns: DEVice, VENDOR, NAME, SPEEd
#  DEV  VENDOR                   NAME                  SPEE
0  1-0  Linux 4.14.131 xhci-hcd  xHCI Host Controller   480
1  1-1                           USB2.0-Serial           12
2  2-0  Linux 4.14.131 xhci-hcd  xHCI Host Controller  5000
[admin@hgw] > /system/resource/usb/print detail
 0 device="1-0" vendor="Linux 4.14.131 xhci-hcd" name="xHCI Host Controller"
   serial-number="xhci-hcd.0.auto" vendor-id="0x1d6b" device-id="0x0002"
   speed="480" ports=1 usb-version=" 2.00"
 1 device="1-1" name="USB2.0-Serial" vendor-id="0x1a86" device-id="0x7523"
 2 device="2-0" vendor="Linux 4.14.131 xhci-hcd" name="xHCI Host Controller"
   serial-number="xhci-hcd.0.auto" vendor-id="0x1d6b" device-id="0x0003"
   speed="5000" ports=1 usb-version=" 3.00"
[admin@hgw] > /port/print detail
Flags: I - inactive
 0   name="serial0" used-by="Serial Console" device="" channels=1
     baud-rate=115200 data-bits=8 parity=none stop-bits=1 flow-control=none
 1   name="" used-by="" device="" channels=1 baud-rate=115200 data-bits=8
name=“” ?! but functionally it is OK.
[admin@hgw] > /system/serial-terminal port=""
[Ctrl-A is the prefix key]
Adafruit MAX31865 PT100 Sensor Test!
RTD value: 32767
Ratio = 0.99996948
Resistance = 429.98687744
Temperature = 988.79
Fault 0xFF
RTD High Threshold
RTD Low Threshold
btw it was a hap ac2 running 7.0b1
re-checked it with 6.45 on MIPS - works as well.
[admin@hgw] > /sys reso usb print detail
 0 device="1-0" vendor="Linux 3.3.5 ehci_hcd" name="RB400 EHCI"
   serial-number="rb400_usb" vendor-id="0x1d6b" device-id="0x0002"
   speed="12" usb-version=" 1.10" [admin@hgw] > /sys reso print
                   uptime: 1w5d12h29m17s
                  version: 6.45.3 (stable)
               build-time: Jul/29/2019 12:11:49
              free-memory: 93.0MiB
             total-memory: 128.0MiB
                      cpu: MIPS 74Kc V4.12
                cpu-count: 1
            cpu-frequency: 600MHz
                 cpu-load: 5%
           free-hdd-space: 96.5MiB
          total-hdd-space: 128.0MiB
  write-sect-since-reboot: 46950
         write-sect-total: 462108
               bad-blocks: 0%
        architecture-name: mipsbe
               board-name: CRS125-24G-1S
                 platform: MikroTik
[admin@hgw] /port> /system serial-terminal port=usb2
RTD value: 0
Ratio = 0.00000000
Resistance = 0.00000000
Temperature = -242.02
