Please, consider to add this feature … It will be a great solution form U RBs…
Regards
Regards
this already works, just get one that has the prolific chip in it. the microsoft gps works fine on mine.
can you givr me the exact model!
cant mikrotik add this to new board layout decine
so there is no need for extrnal gps?
[admin@MikroTik] /system resource usb> print
DEVICE VENDOR NAME SPEED
1 1:2 Prolific Technology Inc. USB-Serial Control… 12 Mbps
[admin@MikroTik] /system resource usb> /port print
Flags: I - inactiveNAME CHANNELS USED-BY BAUD-RATE
2 usb4 1 GPS 4800
[admin@MikroTik] /system gps> print
enabled: yes
port: usb4
set-system-time: no
[admin@MikroTik] /system gps> monitor
date-and-time: sep/19/2009 10:25:11
longitude: “E 8 xx’ 2’'”
latitude: “N 56 xx’ 52’'”
altitude: “29.600000m”
speed: “0.926000 km/h”
valid: yes
Works like a charm!
Not all uses the GPS, and it’s best with a external GPS since you can get a better signal…
But where are you located? maybe someone can send you one og point you to a place to get one…
I´m trying with a Garmin GPS18X … (I suppose it´s the most popular USB GPS)
It´s that compatible ? or Where can I see compatibles USB Devices ?
Regards
it needs to be NMEA based. I don’t know if Garmin is some proprietary format. I wil ltry to find the model that I am using with good luck.
Garmin 18X USB is not NMEA ![]()
And nothing is detected when I plug it on the USB port… that´s normal ??
Also AmbiCom Model GPS-USB works…
Not the MOST sensitive, but it works… would be fine with little “overhead” structure.. IE not in a lover floor of a multi floor building…
Remember to use 4800 baud for the AmbiCom usb port…
