Need to be able to push specific route to vpn client.
MS RAS does it. Why can’t ROS ?
It has been a while since I set this up (and that was on IOS not ROS), but isn’t this done with DHCP options? It looks like you can configure those in ROS.
you can but RouterOS won’t push it to VPN clients. it’s some Microsoft’s extension to PPP (?) and it’s not supported by RouterOS ![]()
Why no? Just make it possible ![]()
I read on the forum using PPP VPN connection it’s not possible to push routes to the client.
What about IPSec VPN or OpenVPN ? It’s not possible either?
It is possible with ipsec+modeconf
Thanks for the info.
Link for other people looking for the same: http://wiki.mikrotik.com/wiki/Manual:IP/IPsec#Road_Warrior_setup_with_Mode_Conf
