Feature request: Winbox and Reset Configuration warning
Hello
Using Winbox v3 wich I use to manage the mik remotely as everyone here !
Yeasterday I think I had make a big mistake, maybe I was tired…
Instead than doing REBOOT, then selected YES, I may have selected RESET CONFIGURATION then yes! And I lost the mikrotik :slight_smile:
Question: Can we add a REBOOT button on the top panel, as the “safe mode” ?
question 2: Since REBOOT and RESET CONFIGURATION are side by side… can we issue a BIG DIFFERENT WARNING if you select RESET CONFIGURATION ?
Thank you
Reboot is a far more disruptive operation compared to Safe Mode…
and what about RESET TO FACTORY? :slight_smile: after reboot the system will be back online…
