I’d like to add my vote to Chupaka’s suggestion. This is a significant concern with MikroTik security since there is no way to force logout an active user. The list of active users can be printed, but there is nothing that can be done with these entries. Presumably, if we had this feature, then we could then create a script to log out any active user after a period of inactivity, though that would also require having some way to determine how long since the last entry from an active user.
Any update on this? I have a router running v2.9.26 that shows several of the same user name active in the “Active Users” list. Now it appears Winbox will not open the router with this user name…it trys, but just flashes the winbox session open and closed very quickly.
I can log in to the router using a different user name, but do not see any command to kick or remove these stale “Active Users”. Any suggestion other than rebooting the router?
Thanks for the idea, but already tried it. These “Active User” sessions are not actually active to anywhere…just hung there still showing active when in fact they aren’t.
