Feature request WinBox: Editable hotkeys + script editor close confirm alert
The hotkeys in WinBox should definitely be editable. In addition, there needs to be a warning alert if the ESC key is “accidentally” pressed in the script source code editor, causing all unsaved changes to be lost without any confirmation prompt. I work a lot with the Vi editor on Linux, where ESC is used to switch from input mode to command mode, and I’m used to pressing the ESC key frequently. However, this is disastrous in WinBox’s script editor...
Bernd
