Feature Request : Winbox Plugin inside Winbox like Telnet
Winbox Plugin inside Winbox :- If it is possible to add a winbox features inside ROS like Telnet/Mac-telnet/SSH. Many times we need to access other routers inside ROS which are not reachable directly from PC. So it would be nice if we can open other ROS on GUI, inside from the RouterOS… :slight_smile:
MT Forum members Your views on this..
How is this different from going Tools>telnet and select SSH or telnet?
Telnet/SSH both are CLI based, i mean some GUI based feature to connect remote ROS like Winbox inside from ROS.
setup a single dstnat rule to forward port 8292 to insideip:8291 and then just use winbox from the outside.
You could also setup a management network that all your devices connect back to via VPN. This is how we do it.
not understanding my Point… :open_mouth:
I want a GUI utility inside ROS like winbox…so that other ROS can be accessible on GUI inside from ROS like Telnet.
I think that he want smething like right click on wireless teble and then Winbox instead of MAC telnet to other router…
Hi pospanko,
have you ever tried Telnet/mac-telnet from a ROS.
When you telnet other ROS, a window opened within Winbox, so is that possible to connect it via Winbox like Telnet inside from winbox.
And yes. I do this all the time. I think that it would be very helpfully that we can open winbox from winbox. Some things is just easyer to do inside winbox instead of CLI.
pospanko
+1
