Feature request: Winbox Resize / Close relocation.
The ‘Close’ and ‘Windows resize’ buttons in Winbox are all the way on the right side of the interface but the most of the other GUI parts are all the way on the left of the interface, on a bigger screen, like my screen at 1920x1080, it is quite the mouse travel continuously going from the far left to the far right.
It would be a small thing, probably the least important of any requests and things on the to-do list, but I think it would be a nifty little feature to be able to relocate the window manipulation buttons to the left on the bar, instead of the right.
It would be even better to simply return to using standard system window frames, as in ROS before version 3. You know, the same boring and predictable kind as every single other window in the whole system has (with exception of some programs trying and failing to look “cool”). With Close button on the right and window menu on the left, which can be double clicked to close the window. I wouldn’t even miss that currently hardcoded blue color, as I’m sure it would work great without it too. :wink:
