feature requests/bugs summary SwOS (RB250GS/RB260GS(P))
Last UPDATED: 18 Jul 2014
!! WARNING, SWOS 1.7 has a BUG, which bricks RB250GS/RB260GS , do not use any ACL RULES with SwOS 1.7 !!
Attention: Since version 1.9 there is a new design of web ui,if you get weired output, power cycle the switch
(check: http://forum.mikrotik.com/t/swos-version-1-9-released/65672/1)
latest: changelog: http://forum.mikrotik.com/t/swos-version-1-10-released/72598/1
RB250GS: http://download.mikrotik.com/swos/swos-rb250-1.13.lzb
RB260GS(SP): http://download.mikrotik.com/swos/swos-rb260-1.13.lzb
i have summarized all feature requests and bugs, i have seen, to have a quick overview. Also, i added some bugs, i have found in my SwOS :slight_smile:
Could any guy from mikrotik give us some info on these bugs / feature requests, so that all customers can see, that there is developing going on ? :slight_smile:
Thanks Ronny
Bugfixes:
new:
will not be fixed
fixed
Official Changelog for SwOS: http://download.mikrotik.com/swos/changelog.txt
  • fixed in 1.6 - Bugfix: SwOS SNMPv2-MIB::sysLocation. is 1. Cisco, Planet, Linksys, 3com all has sysLocation.0
  • fixed in 1.6 - Bugfix: SNMP: Values for “IF-MIB::ifSpeed.x” are wrong (Value: 100Mbits link=> 150 | 1000Mbit/s link => 152), needs to be 100000000 intead of 150 and 1000000000 instead of 152
  • fixed in 1.6 - Bugfix: SwOS Web Interface Error (http://forum.mikrotik.com/t/swos-web-interface-error/44351/1)
  • fixed in 1.6 - Bugfix: Problems with high latency or slow speed links and connecting to RB250G
  • fixed in 1.6 - Bugfix: Problems with passwords
  • fixed in 1.7 - Support for RB260GS
  • fixed in 1.7 - updated web look
  • fixed in 1.7 - setting link speed (without autoconfiguration) did not work (allways 10Mbits was used)
  • fixed in 1.8 - Bugfix: SFP Port information missing with SNMP on RB260GS - http://forum.mikrotik.com/t/rb260gs-swos-1-7-snmp-bug/63963/1
  • fixed in 1.8 - Bugfix: RB260GS: SFP LED diode (UD601) does not work - http://forum.mikrotik.com/t/rb260gs-swos-1-7-snmp-bug/63963/3
  • fixed in 1.8 - Bugfix: RB260GS: Setup SFP port for tags (trunk) / Traffic from/to SFP port has no tags (striped) regardless of the setting. - http://forum.mikrotik.com/t/feature-requests-bugs-summary-rb250gs-rb260gs/45095/1
  • fixed in 1.8 - Bugfix: RB260GS: If i add 2 or more ACL rule - config file don’t make export with button “Save Backup” (not tried with RB250GS) - http://forum.mikrotik.com/t/rb260gs-swos-1-7-snmp-bug/63963/3
  • fixed in 1.9 - fixed logout not working / power down port, when it is disabled / fixed problem - RB260G wasn’t reachable over VLAN
  • fixed in 1.10 - fixed problem - sometimes board did not reboot after upgrade
  • fixed in 1.10 - fixed problem - hosts tab stopped working if 0:0:0:0:0:0 was learned on RB250
  • fixed in 1.10 - fixed problem - broadcast correct uptime to it’s neighbors
  • fixed in 1.10 - allow to disable/enable auto negotiation on SFP port on RB260
  • fixed in 1.10 - enable transmit on SFP port only when module with signal is detected (RB260)
  • fixed in 1.10 - fixed problem - port lock & lock on first did not work on RB260
  • fixed in 1.10 - fixed problem - port full duplex setting was set for wrong port on RB260
  • fixed in 1.10 - fixed problem - port egress rate did not limit traffic properly on RB260
  • fixed in 1.10 - added vlan-id to static host table (RB260)
  • fixed in 1.11 - added support for RB260GSP
  • fixed in 1.12 - fixed problem - SFP port stops after ethernet port cfg change (RB260 only);
  • fixed in 1.12 - change default vlan mode on RB260 to ‘optional’;
  • fixed in 1.12 - fixed problem - SNMP worked even when disabled;
  • fixed in 1.12 - fixed problem - SFP autonegotiation setting was not saved (RB260 only);
  • fixed in 1.12 - fixed uptime to be correct;
  • fixed in 1.12 - fixed RB260GSP poe-out to work correctly after downgrade & upgrade back;
  • fixed in 1.13 - allow to disable SFP port;
  • fixed in 1.13 - do not disable SFP port if loss of signal is detected, some SFP modules do not report it correctly;
  • fixed in 1.13 - make autonegotiation work better;
    acknowledged / being worked on
  • none yet
Features
new:
not possible features (due to hardware limitations or inefficiency)
  • Feature: CLI through SSH / or telnet (http://forum.mikrotik.com/t/feature-request/42120/1)
  • Feature: SNMP: Version should be configurable(I prefer 2c or better 3 with simple user encryption for security)
  • Feature: LACP Channels possible
  • Feature: Remote Syslog
Hardware issues
