First off thanks for adding the script option in the dhcp-client. . That is so awesome to have vs running a IP check script on a time basis vs event trigger.
and thanks for the http post ability for fetch. Its awesome being able to connect to REST API’s.
However it would be nice to have:
- The option to specify distance of default route when “add default route” is used.
- The option to specify a routing mark that can be used when “add default route” is used.
- Random number generator would be cool even though 0.01% would use it
I realize that we can accomplish this to some degree using routing filters but I feel it would be a worthwhile feature to have centralized.
Again thanks for the many new features. I know much of the forum is devoted to complaints but I do appreciate the work.
We need a Mikrotik store where we can buy coffee mugs, shirts, a bust of Normis etc ![]()
