I’m using OpenWRT in metarouter and I’m missing some features. This features should be useful for many other users of metarouter.
1) Export Image
Ability to pack OpenWRT (or other OS) installation into the image and then put the image to many routerboards.
2) Buttons F1 - F12 in console
Buttons F1 - F12 are not working in console of winbox. They are important for Midnight Commander and other linux utils.
3) Ability to use storage card for metarouter (microSD, …)
4) Shared directory for RoS and metarouter
When I make a file by OpenWRT, I would read this file by RoS script. It should work reversely too. It is simple way to make RoS and OpenWRT cooperate.
Maybe one way is to access the file system of OpenWRT via Files in RoS.
5) Metarouter in RB600
Is it planned to be in future ?
Thank you for your opinions about these features.
