Feature Requests
Hello.
I am Dude user and want to see some features in the future releases of The Dude.
  1. Unicode support
    I am Georgian and I cant name devices on Georgian. Cant customize email notification on Georgian and etc.
  2. Linux server and client.
    Most of monitoring servers are running under the Linux, cus it’s a server platform. If you will make Dude for linux, The Dude will become veery popular, cus it have big potential for monitoring not only mikrotik devices.
  3. SMTP auth support. Veery many users are using Gmail SMTP server.
    That users who use The Dude on windows or Linux, are forced to build smtp reley server to make work dude’s email notifications with gmail.
  4. I am monitoring devices with many services, ping, cpu, disk and etc. Sometimes one service is down but it’s not mean that device is fully down or it’s not working. But email notifications is sending and sending. Please add option to run notification when device is fully down.
    Dude users, please write your feature requests in this topic :slight_smile:
p.s. sorry for my bad English.
  1. Will check
  2. Client works perfectly in Wine. No plans for native programs
  3. Will see
  4. Wrong configuration, you can control all of the aspects. http://wiki.mikrotik.com/wiki/Main_Page
EMOziko,
  1. You might have the notification advanced setting to send an email when the device goes from Up → Unstable.. I usually remove that entry from my notifications so it only alerts on the following…
Down → Up
Unstable → Down
Up → Down
This way you will only get an alert when the probe/device is actually down.
Hope that helps.
up->down and down->up don’t happen unless you monitor only one service, usually there is unstable in between.
Another good feature is the ability to change state on parent map when nesting multiple sub maps. As described in:
http://forum.mikrotik.com/t/nested-sub-maps/41797/1
  1. Please fix bug. When I add my IP range in syslog, all IP’s have access to my syslog. syslog feature have bug with IP ranges.
  2. Please add Syslog SSL encryption feature .
  1. Please add more controll of user permissions, like winbox command blocking and etc.
  1. Please add more options in syslog filter
