Feature requests
It would be great to have possibility to send SNMP commands from MT to some network devices. My problem is that I would like to send command to APC to turn off outlet X and bring power again after Y seconds on some events.
Edit:
And of course Adaptec raid controller driver or (&) Intel raid controller support. We are using this for greater demands customers http://www.supermicro.com/products/chassis/1U/502/SC502L-200.cfm
There is space for 2 SAS HDD mobo have Intel and Adaptec controller integrated ad would be great if we have redundancy of 2 hdd in router
Add new filter “connection mark X” to the Torch to be able to track the performance of the PCQ/Queue Tree
I also have an “internal” feature request: better granularity for multi-cpu/core x86 systems.
In systems running multiple full bgp feed peers the table will grow quite big. 3 bgp full-feed peers with one ibgp peer with redistribution will grow the table to +1M routes.
I do not know how ROS works internally but I can tell you this: if I have firewall, qos and BGP active, that’s trouble every time we get high packet rate (+100kpps), every time the firewall will do something, or every time there will be some dynamically added routes to the main table. The router will just go into resource starvation.
For example: if we disconnect and reconnect 2 peers, one core will go up to 100%, mostly everything else will lock up, winbox will disconnect and sometimes all the peers will disconnect.
I find this a very serious issue and it should be resolved by adding the possibility to specify which ROS process would go to which processor/processing core. For example we could specify that bgp instance default would go to cpu 0 and the firewall would be processed on on cpu 1 instead of automatically using the same cpu for everything the router does software and putting that in 100% which will sometimes break things.
EDIT: and oh yes, support for +2 GB of RAM.
even more: not only ‘on connect’ and ‘on disconnect’, but ‘before connect’ so that it would be possible to set, for example, server address from the list of servers (RR DNS, etc.)
In Winbox, add two options to right click when clicking on a wireless client in the registration table to allow (1) Bandwidth Test and (2) Launch Winbox to open client in addition to existing mactelnet, torch etc.
It would be really nice to have this feature integrated. Just a few words why it’s really needed:
There are a couple of RB hardware models oriented for home use. And a lot of home users (at least here in Ukraine) have IPTV from their ISP and prefer working over wireless. However transmitting multicast over WiFi is always a bad idea because multicast over WiFi transmits without acknolege and therefore uses the lowest possible rate to assure packets delivery. Yes, it’s possible to increase base rate for multicast, however the more we increase rate, the more packets we lose. That’s why you will never get fast rate for multicast over WiFi. At the same time proxying multicast to TCP can offer maximum rate with no packet loss.
Honestly, lack of udpxy functionality in RouterOS is the only thing why I can’t suggest RouterBoard hardware for a lot of home users. I mean, each user who has IPTV from his ISP. Here in Kiev, those are at least 30% of home users.
Don’t know how to add feature request in Wiki so adding here
Winbox Plugin inside Winbox :- Is it possible to add a winbox features inside ROS like Telnet/Mac-telnet/SSH. Many times we need to access other routers inside ROS which are not reachable directly from PC. So it would be nice if we can open other ROS on GUI, inside from the RouterOS… :slight_smile:
Added request for MLPPP client support on PPTP on the wiki, hope that someone will take a look at it !
Oukey, so why are on different places made oportunity to allow access only from specified IPs ? /ip services /user and so on for example ? :sunglasses:
I have so feature reqs … I think useful for a lots of users :sunglasses:
    • read out of serial port, in script, not in terminal only
  • 1-wire bus support
  • script debug posibility (error report e.g. like PHP)
  • export/import winbox list to useful format like CSV, not address-book format only
  • quality and complete MIB file for SNMP read/write
  • posibility to make/read/change files directly in Winbox (like F3/F4 in midnight cmdr)
  • option to run script at scheduler not only upon specified time but also upon specified event like system power on, wireless running-check on/off, uplink signal under/over, ethernet on/off, …
The most needed feature is read out from serial port and to run script upon even.
What you think about ? :sunglasses:
Is it possibile to implement simple web browser?
It is useful if you have lots of generic client CPEs with bridged interface and need to set those CPEs with fresh settings. usually they have some 192.168.xx addresses. And we have to make eoip tunnels to do access those cpes.
With web broser all you have to do is add another Ip on interface and then easily access CPEs.
EoUDP - Ethernet Over UDP, similar to EoIP, but carries data over UDP. One end is ‘server’, one end is ‘client’. Server port can be set to user’s choice, client port determined by OS/NAT. Has adjustable ping to maintain end-to-end connectivity. Simple and high performance ethernet tunneling for scenarios where one end cannot use Layer2 protocols (EoIP, IPIP, etc) for whatever reason.
DNSCrypt - new OpenDNS feature, we now have to use client for mac or windows, it installs proxy on local comp which makes encrypted dns requests for you, i think it would be easy to implement this in routeros beacuse it already has dns server, some of the modded router firmwares already has it
tnx for your support
Create network interface over USB with Apple iPhone. Open source iPhone tethering driver for Linux has been available for some time now (ipheth) and I think it is now part of the kernel…
Unmetered content for ppp server specially in pppoe server . a featue which a router allows not to count some addresses in radius accounting .
for example we want pppoe users don’t pay for opening www.mikrotik.com
+1, extremely actual :slight_smile: I’d even upgrade my v3.28 pptp concentrator to v5 or even v6 :slight_smile:
Hi
Would it be possible to have a ‘Port List’
Sort of like the Address Lists just with ports
I do ALOT of Mangle and port forwarding both for Myself and client and always comment exactly what each port is for to save myself time/confusion later on.
It would make things alot easier (for me at least) if I could handle them via one page, as I do with my Address Lists.
It would be great, one “like” for udpxy. :smiley:
well, now (v6, AFAIR) ROS can send mutlicast paskets as unicast frames, so udpxy is not actual just for wifi
Hi team,
i don’t know if this request has been made but it will be possible this “parent proxy that need user and password for authentication?”.
I saw this topic and seams that has end into 2008:
http://forum.mikrotik.com/t/proxy-authentication/20695/1
Best Regards,
Daniel
