Added another request: logging of interface status changes.
Rough example: 29 Oct 2010 16:02 +10:00 Interface ether1 changed from no link to connected 100/full (auto)
This is extremely useful in other managed switches so that you can see if a particular device is losing physical connection or changing speed/duplex for no good reason.
Not often, but handy to know when customer is calling you asking about bad link performance
If you’ve already gone to the trouble of putting in logging of up/down status: whats the harm in also putting in speed, duplex and auto/manual negotiation also?
My request is for a “Auto Roll back” option for upgrades?
(1) full backup is stored on the router,
(2) after uploading upgrade you reboot but…
(3) if for whatever reason the new upgrade caused loss of connectivity or you may have forgotten to change a setting before you clicked reboot …
(4) having a default 5min countdown to restore on reboot,the router will automatically restore the original configuration back,
(5) if no loss of connectivity you can stop the countdown to restore original OS,
(6) the roll back file remains stored on the router, this for fast restore if say after a few days the upgrade has created new issues?
What i am suggesting is similiar to video adapters when you change display setting it automatically restores back after 15seconds if “use” new setting are not clicked,
If you cannot access the router to stop the countdown then wait 5mins and your router will auto roll back to the original OS before upgrade and connectivity should be restored?
Ability to use more options of the VPN server (like those normally speficied in the .conf file of the OpenVPN server when running on Linux)
For me presonally the following option would be really nice:
I would like to set the timeout for pppoe-client connection, which sometimes takes longer to connect. If it is possible to set a time delay that is used to connect each time after a disconnect.
We have some sites that are very noisy RF environments, and they occasionally screw up ethernet links. We’ve tried various remedies, which I won’t go into here, as this isn’t the appropriate thread for it, but it would be handy to have logging of the speed/duplex for us as well.
