Feature requests
I might me a bit wrong but why don’t you just use NAT?
Never heard of that before, but I did similar things in the past using “netcat” (“nc”)
We have several applications, where local devices cannot change their default gateway (DSL or LTE modems for example), which do not point to the mikrotik router. So port forwarding does not allow uns to access these devices from remote (telnet, SSH, webinterface, SNMP, …).
You can do the same thing on a MikroTik using a src-nat and a dst-nat rule!
A local linux box running rinetd gives us access to this device. But a local linux box adds €/$ 200,- to the budget.
HOW???
A local linux box can be a Raspberry Pi which would be more like $50.
Would like to see a Radius tester available for the “Tools section”. Something along the lines of Radtest, so you can see that the external radius server is actually getting something from the Mikrotik router, and if not what the problem may be to fix it. Currently there is not enough information available in the Logging to help you on that.
Another +1 for me. Please implement this, as WireGuard is steadily moving towards mainline kernel inclusion.
Virtual private networks with WireGuard
In Winbox I think the Dashboard menu could go away and just have all of it’s items enabled by default. Unless there’s some reason people don’t want to see this information or there is some amount of overhead on the router.
If it can’t go away, it would be great if it would at least remember my settings between routers so that I don’t have to re-enable them to compare times more easily between routers that are having IPSEC negotiation problems or when the CPU is maxed.
This is just a special case of the generic feature request to have some way of sharing settings in winbox between a large number of routers.
Some other requests have been seen to e.g. allow “set current winbox settings as default for new connections” and/or to simply allow
the sharing of the same settings between all routers in a Group.
This is already possible.
Connect to one router. Set columns you want to see, open windows etc.
Select session/save as
Next time before connecting to new router pick saved session.
  • there should be some way to “save as default”
  • there should be some way to interconnect the settings of a Group, so when you add some column to one window in one router out of that group, it is then also shown in all other routers from that group that you already had added (maybe some way to allow an entire group to share a single session file)
  • and of course: the widget to select colums should be improved. add a dialog that can be opened that shows all possible columns with a checkmark field, allow the user to select/unselect multiple columns, and click OK to finish. this instead of the cumbersome column list that has to be accessed via 2 levels of menues and often does not fit on the screen so has to be scrolled as well.
urgent request to (for) mikrotik
http://forum.mikrotik.com/t/urgent-request-from-mikrotik-please/117577/1
But then I have to do that on each of the hundreds of routers in my Winbox managed sessions list… Right? I guess my point is that I see no reason at all why someone would not want to see the dashboard information in the upper right. Is there a reason? It’s just extra stuff (menu options) that doesn’t need to be there. Turn them on all the time for every session and just get rid of the Dashboard menu.
Unless there’s some reason that I’m not seeing?
Please increase Simple-Queue limits - they max at 4,294 Meg (aka 4.294 Gig)
ROS Simple-Queue - please increase the possible maximum limits and thresholds.
Currently on v6.41.3 and v6.41.2 (don’t know about older versions) ,
The maximum possible value for “Max Limit” and “Burst Limit” and “Burst Threshold” is “4294M”
The Simple queue will not accept any higher numbers.
This presents a problem. I have multiple 10-Gig networks and on some networks I must use bandwidth limiters which are much faster than the built-in restricted values.
An example of need: 10-Gig physical Internet connection - Purchased Internet speed need to be maintained by my network equipment. Problem - the Mikrotik ROS will not accept any values greater than 4294M in any of the Winbox Simple-Queue fields
North Idaho Tom Jones
Seems like setting is set in 32-bit integer with unit of bits per second. This might pose an architectural problem and we can only hope it can be solved easily.
Perhaps by giving us possibility to set unit … e.g. bits/second (default, current setting) or kbps (gives 1000-times higher limits) or Mbps. After all, with Gbps speeds it is not really sensible to set limits with bps resolution. Or is it?
That is correct, the underlying Linux mechanisms being used have limitations and it was likely designed with the rationale “when you have that much bandwidth
it is not really required to shape it”. It also would incur a lot of CPU overhead to do that.
This is what I have been asking for several times over the years. It’s good someone else now asks again.
Somewhere some Mikrotik guy decided what the default settings are when on a virgin router a virgin winbox is openend. I would like to be able to just change that ‘virgin’ setting myself.
By default winbox shows a lot of info I have never interest in. But many other field I need everytime again are not there by default… Especial when you work with many PC’s it would be easy to have one winbox.exe that is everywhere the same to MY like.
Well, I would suppose that if somebody (like me) needs a simple-queue setting in any of the fields greater than 4294-Meg, then they are likely running something with a big-beefy-CPU , such as a CHR on a fast Xeon processor or possibly a high-end or current or future Mikrotik hardware product.
I am pretty sure my CHR-x86-64Bit and my ROS-x86-32-Bit systems have plenty of CPU horse-power. All of my virtual ROS systems can btest to 127.0.0.1 in the 19+Gig ranges. (btest uses only 1-core. Now if you use 8+ cores (hyper-threading disabled for maximum CPU throughput) then I would assume possible system-wide-throughput might be 8x greater.
(My next hyper-visor system I am planning to build soon will allow me to configure 44 Xeon CPU cores to a hosted system - such as a CHR.)
Also , just about all new carrier-grade network equipment has one or more 10-Gig interfaces. Thus another reason for a simple-queue fix/update is needed.
Also - remember the Mikrotik post about “What would you like to see in a future Mikrotik …something… with a 40-Gig throughput…” Thus another reason for a simple-queue fix/update.
Everything in my server room and my Internet feed uses 10-Gig interfaces. And I need an ability to use simple-queues up to 10-Gig.
+1
It works for SSH but it would be really good to make Winbox to be able to authenticate via radius.
Hello
to disable DNS attacking
please add listen address on better from use ip firewall filters
/ip dns allow-remote-requist=yes
/ip dns listen-src-address=192.168.88.0/24,x.xx,y.y.y
Regards
Cant you already do that via firewall, dont understand what more you need, if you want to block DNS requests form outside net, or alow only DNS requests from that ip range simple make firewall rule with tcp/udp 53 ports..
All other services have something like that. Api, ftp, ssh, telnet, winbox and www have “available from” option in IP->Services, smb allows to choose interface. If it makes sense for them, surely it would make sense for dns too.
Can you add a feature in User manager which support WPA EAP and add 6to4 tunnel to vlan or bridge, please?
