would it be possible to list ospf and bgp when.i do an snmp request using observium or librenms, as right now it does not list anything, vyatta, edgeos, quagga, cisco all show up but mikrotik does not show. i remember that it worked fine till version 6 was released then it stopped working for some reason.
aah is that the same as for OSFP? a friend of mine mentioned to me that version 7 is made of unoptanium, any hints as when to expect this magical version, would it be i like a few months or a few years? would be nice to know when it would show up
You might be able to script it for Observium to monitor your mikrotik through the API.
We use Zabbix for monitoring, so for BGP monitoring we have a script with connects to the mikrotik API and returns information which zabbix can monitor.
For example:
# ./bgpcheck.php exabgp uptime
3w4d12h54m53s
# ./bgpcheck.php peer1 uptimeseconds
2206497
# ./bgpcheck.php peer1 status
established
We then create an alert on say the status of a peer connection to notify us if the status is not “established”
It shouldn’t be to difficult to do the same for observium.
[quote=“Murmaider”]You might be able to script it for Observium to monitor your mikrotik through the API.
For example:
3w4d12h54m53s
2206497
established
I devised a “roundabout” way to monitor bgp peer state. I created a script that checks for all bgp peers and creates a “dummy” bridge interface for each. Then it will enable or disable the bridge state depending on the bgp peer state. You can then setup monitoring of the “bridge” interface which in essence reflects the state of the BGP peer.
You can decide how frequently you would want to run the script. You can also remove the “:log” lines - I added it while creating for debugging purposes as I don’t create scripts very often.
Perhaps someone could streamline or suggest edits.
You can add this to a schedule to run as often as you want.
:global peername;
:global state;
/routing bgp peer
:foreach peer in=[find] do={
:set $peername [get $peer name];
:set $state [get $peer state];
:set $bridge “bgp_status-$peername”;
:log info “bridge name = $bridge”;
:if ([/interface find name=$bridge] = “”) do={/interface bridge add name=$bridge disabled=no};
:if ($state!=“established”) do={/interface bridge set [find name=$bridge] disabled=yes} else={/interface bridge set [find name=$bridge] disabled=no};
:log info “Peer Name = $peername Status: $state bridge name=bgp_status-$peername”
Derrick, I was thinking about extending the idea of the virtual interfaces to OSPF. Doing something like monitoring adjacency count, and downing the bridge using a timer (for detecting flapping). Have you tried this?
I think this is related, I run Observium to monitor some Mikrotiks (CCR1036’s), and I do not get any routing information.
Am I running into this thread issue?
Observium documents state this, just wanted to check with Mikrotik before I log a fault with the software.
Mikrotik RouterOS
CPU and Memory statistics are available via HOST-RESOURCES-MIB. MIKROTIK-MIB is not yet supported. Sadly BGP4-MIB is not currently supported by RouterOS. https://imgur.com/b85uaql
