I presume most of us when aligning directional antenna’s work with sighting first (if possible) and then fine align with the reading of the signal strength in either the align tool or just in scan mode or if connected in signal strength reading in the wireless-registration menu.
I also presume the majority uses a laptop or netbook to get the readings while hanging in a mast (or standing on a roof or other high object!).
Then we all must have occurred that when in broad daylight, when the sun shines, or when the laptop is on the floor because both hands are needed to align the antenna while you have to keep yourself to the mast, the reading of the signal levels becomes very hard..
Can MT consider the option in for instance winbox align window to blow up the signal strenuous to full screen or at least much bigger then just the small figures we have to discover in a relative small window in a hardly visible screen?
Any support for this? Please back this up and hope MT can achieve some. They are lab guys, we have to work with the units day to day in outdoor conditions. Please make our lives a bit more easy MT!!!
And has anybody ever invented the use of the audio monitor in the ROS? Info or shared experiences is very little…
rgds
