Feauture request: OpenVPN authentication improvment
Since version 7 have new openvpn UDP support feature, сan you please also add standard authentication methods with certificates?
Currently unsupported OpenVPN features
TLS authentication
authentication without username / password
I would also like to see the ability to push route or other custom settings, for example raw configuration file lines like options in DHCP server.
and also sha256 :slight_smile:
So what is the status? Is there any reply from official Mikrotik support? A “no” would be still very very much appreciated because it is an answer, instead of a “don’t know”. Thank you! :slight_smile:
