Feautures Request - Wiki Page: Vote for feautures!
http://wiki.mikrotik.com/wiki/MikroTik_RouterOS/Feature_Requests
Can it be made as announcements?
about features requested
configuration rollback:
/system backup save file=theName does not work?
safe mode does not work?
or where is problem?
I mean rollback like in JunOS (Juniper routers).
For example, there is 10 slots, where 10 configs stored automatically after commit.
about save mode - it will be activated automatically
just make backup, if you made changes that are worth saving - save backup, export config, because then you will get meseed up, when autosave will overwrite some important part of configuration and you will loose it.
I think it would be convenient for both:
  1. Safe mode activates automatically
  2. You make some changes
  3. type commit (exit from safe mode)
  4. configuration became applied to router
3.1) if you type commit 1m (exit from safe mode)
4.1) configuration became applied to router
5.1) if not confirmed in 1 minute, rollback to previous configuration
3.2) if you type commit at 23:00 (exit from safe mode)
4.2) configuration became applied at 23h 00m
if you know your last good configuration, you type “rollback ”
Where - automatically stored configuration in FIFO RR queue (f.e 10 items). Configuration written to slot after each “commit” command.
It is very useful!
