How to access data variable when I use output=user?
[admin@mtTest] > /tool fetch output=
Output ::= file | none | user
none – do not store downloaded data
user – return up to 63k bytes directly in ‘data’ variable without storing on disk
file – store to file
Unfortunately it doesn't work (real IP hidden). I dknow that I can write it to file but that is not what I like and this new option (output=user) will be great if
only I can get it to work. There is no explanation for it on Wiki at this time.
any idea how to do this when you have multiple isps to get address of all providers ?
mine are set with different distance in routes and mangle input/output to specific routing tables. so all traffic goes out the main isp, but the router can be reached over all isps.
i tried with src-address but i always get the reply of the main isp. I also tried setting a specific route for ipify but it didn’t work.
is it a security concern that I’ve missed in the bigger picture ? … or is it just forgotten to be implemented ?
a SNMP-OID gives back (most of the time) one decisive piece of information from a tree …
a html-request gives (normally) back … a … … a tur*
please walk me through
(obviously !)
the post was about: why is it implemented for a comparable method (fetch) and the possible reasons ( … why not for snmp)
… so please read more diligent
I’ve searched the forum … found your post … and have not implemented it
halfway the reason I’ve posted this question
