fetch http-data how to send properly an array
I cannot find the way to post the data properly using http-data option of fetch command (I know it is only in the RC version still 6.39rc62)
I am trying
tool fetch http-method=post http-data=$myVar url=http://example.com
but I the value is sent as the name of the post variable with an empty value
I want to be able to define in plain format
serial=1231454525
model=rb951 and so on
anyone knows anything that could help?
Use this function:
# convert object to json
# Params
#   objectParam
# Returns
#   String json representing object
:global toJson do={
  :global toJson
  :local ret "{"
  :local firstIteration true
  :foreach k,v in $objectParam do={
    if ($firstIteration) do={
      :set $ret ($ret . $k . "=")
    } else={
      :set $ret ($ret . "," . $k . "=")
    :set $firstIteration false
    :local type [:typeof $v]
    :if ($type = "array") do={
      :set $ret ($ret . [$toJson objectParam=$v])
    } else={
      :if ($type = "str") do={
        :set $ret ($ret . "\"" . $v . "\"")
      } else {
        :set $ret ($ret . $v )
  :set $ret ($ret . "}")
  :return $ret;
To add on Ricard2k’s function and make it JSON string, write it as follows;
:global toJson do={
  :global toJson
  :local ret "{"
      :set $ret ($ret . "\"".$k . "\":")
    } else={
      :set $ret ($ret . "," . "\"". $k . "\":")
    } else={
      } else {
  :return $ret;
Then you can use Javascript’s JSON.parse to decode the string to JSON
This is excellent – thank you!
I had some trouble figuring out how to invoke this, so here’s an example for the record:
:local msg ({});
:set ($msg->"cpuLoad") [/system resource get cpu-load];
:set ($msg->"temp") [/system health get temperature];
:set ($msg->"cpuTemp") [/system health get cpu-temperature];
:put [$toJson objectParam=$msg]
Outputs: {“cpuLoad”:1,“cpuTemp”:54,“temp”:47}
