fetch http response and headers
How do I retrieve the http response headers from a fetch call please?
The result->”data” element appears to only contain the body of the response and not the http header - not a lot of use as I need to extract the HTTP response code and Set-Cookie fields for the script I am developing.
J
You can access “data”, “downloaded”, “duration”, “status” and “total”. Looks like your requested information is not available.
Thanks for the reply; sounds like a “fetch” feature request unfortunately.
This is pretty fundamental functionality; does anyone know of a workaround in the meantime please?
J
