how can I download the latest version of the router on the switch?
that does not work
:global platform [/system resource get architecture-name];
/tool fetch url=“sftp://192.168.111.254/routeosVERSION.npk” dst-path=“routeosVERSION.npk” user=“test” password=“test”;
Rugx
2
:local vers "7.1.2";
:local arc [/system resource get architecture-name];
/tool fetch mode=https url="https://download.mikrotik.com/routeros/$vers/routeros-$vers-$arc.npk"
Of course if you don’t want to manually set the $vers variable, some other shenanigans will be required
The usual
/system package update install
is not sufficient?
Rugx
3
If you are looking for rOS version 6.x, change places of the $vers and $arc, as for some reason they are reversed there:
.../routeros/$vers/routeros-$arc-$vers.npk"
